My Banshee won't run right!!!!
Old Dec 24, 2010 | 11:26 AM
96YamahaShee96's Avatar
Default the gas switch
if your gas switch is set to reserve (RES) then it saves gas by only using the left engine/pipe. mine does the same. and it runs rough like that. it may look like its on GAS ON. but the long end should be down. just a suggestion. hope you find out the answer.
Old Jan 24, 2011 | 03:46 AM
sparsons250r's Avatar
haha i got a shee the other day and got on it started up second kick idled fine then took off on it and it felt like it was running on one piston so i hope your right about the reserve cause thats what i had the gas on and its to cold for me to pull the carbs off lol
Old Dec 24, 2012 | 02:15 AM
rjenx's Avatar
If you put new reeds in the reason it is backfiring is because you need to rejet the carbs.also adjust air screws .aftermarket reeds on banshee are a big upgrade should also do k&n filters and pipe to go with it to make jetting easier.
Old Dec 24, 2012 | 02:22 AM
rjenx's Avatar
Running your banshee on reserve will not cause it to run on one cylinder the only thing different is it pulls fuel from a lower point on the tank.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
