Best Drag Cam for Raptor
Old Mar 9, 2004 | 06:50 PM
lilMike's Avatar
Default Best Drag Cam for Raptor
I've narrowed it down to these 2 cams. Has anyone tried both cams and have times to show the difference between the two cams. The drag would be the 300ft and some 1/8th mile. Thanks
Old Mar 9, 2004 | 11:06 PM
Mr45auto's Avatar
Which two would that be?
Old Mar 9, 2004 | 11:12 PM
sixsixT's Avatar
Need a little more info. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 9, 2004 | 11:28 PM
BigScary's Avatar
[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 10, 2004 | 01:32 AM
lilMike's Avatar
sry, i typed that right before class tonight. between the stage 2 or web cam 685 grind. I did some calculations... the stage 2 came out to like a .385 lift, the web cam is .452. W/O writing the whole formula out, it comes out to the stage 2 is within .007 is the specified lift. So according to the Motorcycle Mechanics Institute the Stage 2 cam, is the right choice if you added over size valves.
Old Mar 10, 2004 | 01:56 AM
bad350twin's Avatar
how about a megacycle cam?
Old Mar 10, 2004 | 01:59 AM
lilMike's Avatar
what is the lift of the megacycle?
Old Mar 10, 2004 | 05:38 AM
Ward660R's Avatar
Mega-cycle makes about 4 or 5 different cams, from smaller than a stage1 to larger than the 685.
IMO your not going to like anything bigger than a stage 2 without doing something in the area of your carbs. And with the low compression your running your not going to have very much bottom end anyway.
You can do a search on here for the mega cycle specs with my name as the author, I posted them recently.
Old Mar 10, 2004 | 06:12 AM
Boxman's Avatar
Ward.....do you ever sleep?[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 10, 2004 | 06:17 AM
Ward660R's Avatar
Not until 5 a.m. LOL
Nice to see you still around Boxman!
