First time adjusting valves!!
Old Mar 13, 2004 | 03:06 PM
jerstilly's Avatar
Default First time adjusting valves!!
I adjusted my valves for the first time today and I have a fe questions. Ok when turning the nut counter clockwise it says in manual to line up the "i" mark on the inner wheel thing. OK I while turning it i noticed there is an "I" mark, looks like an H when looking into the hole..I used the line that looks like a straight line that comes right after the H looking mark while turning the nut..did I use the right mark or am I to use the H looking mark.. Also my valves were done at the start of last season and my intake valves weree REALLY tight, but my exhaust valves were OK...is this normal??? THNAKS ALOT
Old Mar 13, 2004 | 04:08 PM
Slowwarrior's Avatar
Sounds to me like you used the right mark.
Old Mar 13, 2004 | 04:40 PM
RoostItUp's Avatar
Yes, thats the correct mark.
Old Mar 13, 2004 | 06:47 PM
sixsixT's Avatar
Yep and the intakes do tighten up.
Old Mar 13, 2004 | 06:58 PM
jerstilly's Avatar
Thanks a lot, do the exhausts not tighten up, or just not as quickly???
Old Mar 14, 2004 | 02:41 AM
hondabuster's Avatar
An easy way to tell if youre on the right mark, and not 360 out...is to wiggle the rockers, if they are tight, and you cant wiggle them, youre 360 degrees out. Rotate the crank one full turn from there.
Heres a generic guide to valve adjusting.
valve adjustment
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
Sjrpp
Jul 5, 2015 09:04 PM
yambam13
Jul 4, 2015 01:49 PM
