Raptor Reverse...NEED HELP!
Old Mar 14, 2004 | 10:53 PM
carguy07's Avatar
Default Raptor Reverse...NEED HELP!
i just got a raptor this weekend, and there seems to be something wrong w/ the reverse. if i get on a hill it wants to start bogging, no matter what. even if i push the throttle all the way in, it'll die. the previous owner put a white bros r-4 slip one pipe and white foam filter on it. it hasn't been jetted, is that the reason it won't pull in reverse? help me please[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 14, 2004 | 11:02 PM
zepman's Avatar
I have had the same problem. I believe it has a rev limiter on reverse, like the parking brake.
Old Mar 14, 2004 | 11:05 PM
carguy07's Avatar
maybe, i'm going to jet it and see if that helps. how do you engage the parking brake? know that's a stupid question, but mine still rolls when i do it the way the manual says. and my brakes are still very good.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 14, 2004 | 11:15 PM
Foxracin's Avatar
Try adjusting the park brake, and it probably dies cause the rev limiter
Old Mar 14, 2004 | 11:16 PM
zepman's Avatar
You can adjust the parking brake on the clutch lever (top one).
Old Mar 14, 2004 | 11:17 PM
carguy07's Avatar
ok, and how do i adjust the rev limiter?
Old Mar 14, 2004 | 11:18 PM
sixsixT's Avatar
There is a rev limiter for reverse. You can bypass it but you rev light won't come on or you can buy a bypass kit that will allow your light to come on but not the limiter.
You still may want to rejet it anyway but that's not your problem.
You need to adjust your parking brake.
Old Mar 14, 2004 | 11:21 PM
carguy07's Avatar
yea, thx.... i still need to rejet it though, just to get the full potential outa that pipe
Old Mar 14, 2004 | 11:25 PM
carguy07's Avatar
i have the wb r-4 pipe and white air filter, does anybody know what jets to get, or where to look to find out? thx
Old Mar 15, 2004 | 12:38 AM
Outlawlawndragster's Avatar
Check this link it works great and it's cheap! http://www.raptortranny.com/revlimiter2.php
