i dont know how to work the reverse
hang on here. get her going, put her in first, turn the reverse **** and push down again. uu might have to put a little pressure on the shifter, mine used to pop out. but u have to have ur hand on the clutch and have it in 1st gear, then push down again whil turning the ****.
while the engine is running you put it in neutral, pull in the clutch, twist the **** labeled Rev. and push down on the shifter if you did this correctly a red light will come on next to your neutral light
#15
Put it into first gear...keep the clutch in...now while still holding the clutch reach down and twist the reverse **** and hold it...now push the shift lever down one more time...it should now be in reverse...let go of the reverse **** and try moving in reverse...sometimes it takes a couple of tries before it gets in...
#17
Originally posted by: caliraptor
Damn right!
Originally posted by: Slowwarrior
Ummmm if this isnt a joke you should be banned from riding period, no offense.
Originally posted by: much2fear
does the engin have to be on?
#20
Don't forget to pat your head and ask 3 times. May I ride you in reverse? May I ride you in reverse? May I ride you in reverse? Then snap your fingers twice. (left hand) Hop off the Raptor and then back on. Off one more time and then back on. Then fart the alphabet backwards. Now it should work but if it does not then try everything two more times. You're supposed to stand on your head somewhere but I can't remember which step that is before or after. Good luck.[img]i/expressions/face-icon-small-happy.gif[/img]
