Banshee keeps poppen
Old Mar 29, 2004 | 08:19 PM
Chazzman's Avatar
Default Banshee keeps poppen
Never owned a banshee before where do i adjsut it?.. But the slide on the choke side carb dosent move it stays in the same place at all times. The right side moves as soon as u thumb the throttle.. Ne ideas or how to adjust it
Old Mar 29, 2004 | 08:54 PM
TRLYFZ450's Avatar
Check the cable. It is ether broken or came unhooked.
Old Mar 29, 2004 | 08:56 PM
TRLYFZ450's Avatar
Take the carb cap off the left carb and see is the cable is still good. it should be attached to the slide.
Old Mar 29, 2004 | 09:21 PM
Chazzman's Avatar
yes its attatched i removed them when i cleaned the carb.. Not sure if i messed something up then but it was poppen before i cleaned the carb, But i didnt check the sldies before it...
Old Apr 3, 2004 | 01:00 PM
  #15
lapeerbanshee's Avatar
you should probably change your gas because if it has water in it, it will pop or it might be your spark plug since its only your left side. it doesnt leak anti-freeze does it? Also check your spark plugs and see if the left side is overheated.
Old Apr 3, 2004 | 04:58 PM
  #16
justforfun350's Avatar
If you move the clip down it will raise the needle thus making the mixture richer. You move the clip up to lean out.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
