Big Bore Raptor Reliability
Old Mar 29, 2004 | 03:49 PM
garyc660R's Avatar
Default Big Bore Raptor Reliability
How many hours do you have on your big bore Raptor? Piston type and overbore, rod, balanced crank....whatever....please list your internals and approx hours. I know a lot are garage cuties......do we have one over 250 hours?
Old Mar 29, 2004 | 11:36 PM
Hayseed's Avatar
Does the lack of replies to this post mean reliability is too embarassing to admit? Should I forget about future upgrades? Watching............
Old Mar 30, 2004 | 03:18 AM
INSeaRChOFDUNez's Avatar
Good thing im spending my money in suspension rather than engine mods.
Old Mar 30, 2004 | 05:47 AM
Yamaha660R's Avatar
My buddy has a Powroll 770 that is going over a year with no problems. No enternal engine let down's, and no problem's to list.
It has a titanium rod, and the crank has been balenced.
Old Mar 30, 2004 | 06:21 AM
Ward660R's Avatar
Honestly mine is a garage cutie (not by choice either...I just have bad luck). I really don't have a whole bunch of hours on my motor, but EVERY single minute is WFO..no doubt. I have not had any engine problems other than the clutch grenading, but I have that fixed now (I hope).
I am a stock rod, stage2, 102mm JE piston, with about 12.5/1 comp. ratio. I keep on top of my valve adjustments and I do change the oil often, because of the methanol, but its a good thing anyway. I say I have about 100 hours on this piston and cam.
As soon as I get my swingarm in I will be testing everything out. I am going to run just asphault now so if something is going to break it should show up.
Done right (with rod and balancing) and taken care of I think a big bore will be just as reliable as a stock motor....well almost.
Old Mar 30, 2004 | 08:42 AM
RAPTORAZ's Avatar
So far my KENZ CYCLE TECH built 727 has been rock-solid reliable. It's got about 75 hours of mostly WOT hill and flat drag racing, and about 60 dyno pulls(I've let Ken use it for a lot of R&D) as well.
Internals: Carrillo rod, JE 12.5:1 compression 105mm piston, crank lightened and balanced, Stage II Hotcam, and Stainless oversize valves.
As well as my bike starts(stock-modded carbs. Fires up instantly, even ice cold, and goes to a high idle), idles, and runs, I'm sure it'll be going for a long time to come.
Old Mar 30, 2004 | 10:27 AM
SANDMAN430's Avatar
seems there was some bugs at first but they now seem to be holding together. just from watching other riders.
Old Mar 30, 2004 | 12:46 PM
TheRaptorMan's Avatar
Going on two years with a Trinity 727 12:1 with stock rod and no problems... KNOCK ON WOOD!!!! This bike is drag race only and is 100% WOT from launch to stop!
Old Mar 30, 2004 | 03:38 PM
garyc660R's Avatar
Thanks for the replies gentlemen. Good too see you around Raptorman.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
black_thunder
Sep 22, 2015 07:59 PM
01ssls1
Sep 22, 2015 06:50 AM
