A hint of Raptor potential?
Old Jul 17, 2000 | 03:06 PM
bash's Avatar
I know that the Raptor has an all new engine, claimed to produce more power than the 660 found in the German bikes that Yamaha produces the engines for. However, I thought I'd do a little searching to see what kind of power they were getting out of the old design.
The engine -- outsourced from Yamaha -- may be stressed structurally, but with a claimed 48 horsepower at 5250 RPM it's definitely not
stressed in the horsepower department. The carburetion on our test bike seemed off at lower revs, but cleared up once the tach passed 4000; unfortunately, by the time you reach this point you've already stumbled through the bottom and mid-range of the power band. After all, the motor only winds out to 6800 RPM. Although the engine spins up freely, it does not make much power near redline or beyond. Uncorking the exhaust and rejetting the carburetor would no doubt improve the throttle response of the bike, as well as provide more power. Racers using the related Yamaha SRX 600 motor claim they can coax almost 70 hp out of their mills; similar tuning tricks could be applied to the MZ's 660cc mill with equally good results.
Notice that the old engine would only turn 6,800 RPM and put out 48 horsepower at even less RPM than that? It seems that Yamaha has taken the good and improved upon it, and figured out what didn't work as well as they wanted and changed it.
The new engine in the Raptor is said to turn 9,000 revs and only stop there because of a rev limiter. If a beefed up enine on the old design can make almost 70hp, then new engine would exceed that!
I'm very pleased after reading this!
Old Jul 17, 2000 | 03:46 PM
99Scram500's Avatar
Well if it could get close to 70 hp, u would be blowing away just about anything. The only thing that would beat u is a totally stroked banshee on alchohol, which makes about 80 rwhp. But there just meant for hill shooting.
But really, a good pipe, cam, and high compression piston will prolly be in the low fifties, atleast thats my guess. And thats is plently enough for most riders.
Old Jul 19, 2000 | 04:50 PM
bash's Avatar
I found some more info on the MZ660 and performance upgrades.
http://www.holeshot.com/mz/mzsc.html
This site is selling a slip on silencer and a carb kit that puts out 46 hp and 49 ft. lbs of torque measured at the rear wheel. We've got to remember that this is on the old, unimproved, low-revving 660 and no the one put in the Raptor though. The Raptor is said to easily rev out about 3,000 rmp more than the 660 used in the MZ. I'm not sure what the translates to, but I'm guessing that it is easily about 5 to 10 HP more just based on the eargerness to rev.
If we mangage to get 55 rear wheel horsepower and somewhere around 60 lbs of torque out of it, it should be pretty good huh?
Here's a chart showing torque figures that ScoobyDFW was so kind to gather up in another post.
These figures are for stock machines.
DS650:
27 ft-lbs @3200 RPM
37 ft-lbs @5700 RPM
30 ft-lbs @7000 RPM
25 ft-lbs @7700 RPM
Banshee:
5 ft-lbs @3200 RPM
23 ft-lbs @5700 RPM
29 ft-lbs @7000 RPM
21 ft-lbs @7700 RPM
19 ft-lbs @9000 RPM
Any comments on how the new Yamaha 660 will respond to modifications compared to the existing 660?
Fire away!
Old Jul 19, 2000 | 08:13 PM
ScoobyDFW's Avatar
Interesting that the aftermarket carb is the same as the ron wood stage 1 kit carb for the DS650, except 42mm instead of 45mm.
Old Jul 19, 2000 | 09:06 PM
quad_man's Avatar
That is very interesting. I guess we won't know until we ride, and dyno them, but I hoping Yamaha redesigning the motor for the ATV chassis is a good thing. Hopefully they won't do like the 400ex and DS650 and make them "slower" than the "normal" motors if that makes any sense.
By the sound of things so far, I doubt it will be lacking power though. But when we can't ride them, it never hurts to share all of the little bits of information we do have and discuss the machines so that when we do eventually get them, we will have some idea of what we are riding on. :-)
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
