how much hp should I have
Old Mar 31, 2004 | 07:18 AM
Shav0's Avatar
Default how much hp should I have
well i was told 19,
and that was straight from a yamaha mechanic.
So no offence JakalWarrior, but im going to go with his word before yours [img]i/expressions/face-icon-small-wink.gif[/img]
Think about it dude, 13hp??? My snowblower has 12.
My blaster with just the pipe would blow a warrior away and I could keep up with one stock. With pipe and filter im only just behind a 400ex.
Get your facts straight before you start posting b/s about stuff you dont know. I think you just dont want to admit a little 200 can kick your a$$.
Old Mar 31, 2004 | 08:42 AM
Yamaha4eva's Avatar
Originally posted by: yamwarrior101
no the stock hp of a blaster is 10. The WARRIOR is 18
TEN HORSEPOWER!!! ARE U ON CRACK?
Old Mar 31, 2004 | 08:48 AM
warrior68man's Avatar
Originally posted by: Shav0
well i was told 19,
riight.
Old Mar 31, 2004 | 11:06 AM
2004LEBANSHEE's Avatar
We dinoed one the other day and it got 6.5 Hp at the rear wheel, It was a fast little bugger. But my new Lawn boy dynoed at a blazing 7.5 at 3,000 RPM. It rips[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 31, 2004 | 11:49 AM
  #15
potentpete's Avatar
A stock blaster, which is pretty much what you have, with a few bolt on's will dyno at the rear wheels at around 10hp, they have around 17-19 at the crankshaft, Hollywood dirt just had a ported blaster on the dyno with an fmf pipe and stock rifled carb which made 23hp at the rear wheels and 35hp at the crankshaft, they had a chart posted on their forums, so with a little porting a blaster can pull some good numbers, but I would say bolt on items aren't going to get you much past 15hp at the rear wheels, you need to open the porting up to get into some good hp numbers for that little quad.
Old Mar 31, 2004 | 01:02 PM
  #16
Shav0's Avatar
How does that make sence because stock to stock my blaster can beat a warrior, no problem
so if warrior stock is 18 or 19, then there is no way the blaster can be like 10.
Old Mar 31, 2004 | 02:22 PM
  #17
RoostItUp's Avatar
The wieght difference is why it keeps up with Warriors...but those dyno numbers are off just like all dyno numbers. It doensn't make 10 hp, Blasters at least make 15 stock. But this thread is becoming a bunch of bull...just let it go.
Old Mar 31, 2004 | 03:46 PM
  #18
potentpete's Avatar
your comparing to totally different worlds with 2 stroke and four stroke, a 2 stroke reaches peak power faster than a four stroke, so its hard to compare HP numbers between the two and which one is faster.
Old Mar 31, 2004 | 03:48 PM
  #19
Why aska question, when you already know the answer?
Old Mar 31, 2004 | 04:17 PM
  #20
WheelieKing's Avatar
for real....... Shavo, why do you talk all this sh*t with your blaster... my friends lil sister has a blaster!! you gotta realize your lil blaster can't do much.... go ahead shavo start start sayin what you want now... i'm not gonna take ne of that back..
