white brothers e-series discs
Yes removing discs from your white brothers will give you less power on the top but it should help with low end and torque to a certain degree.Removing discs also will quiet your pipe down some.
Less Discs = Less noise = Less Top End = More low end torque
More Discs = More noise = More Top End = Less low end torque
Remember not to add too many, or you could lean out your machine too far and whallah.. meltdown.
No( eceriderjbomb) i am correct and i know this because i have used pipes such as supertrapp and white brothers for many years and believe me less discs means quieter and more low end and more discs just the opposite.
If you tske the spark arrester out you would not need any disks... It said on the wb page that came with the pipe that taken all of them out wouldrny exacltly give you more hp. You wil need to do proper jets for each diffrence you do wo the pipe.. Invcluding changing disks if you want maxiumim performance
