what happened?
Old Apr 2, 2004 | 04:33 PM
bansheegirl01's Avatar
Default what happened?
The other day, i rode my bike hard then let it set and idle for about 15 minutes, i came back outside and some antifreeze had spit out of it, just a few drops. Did my shee overheat? It is a stock shee, except for a boost bottle.
Old Apr 2, 2004 | 06:30 PM
lapeerbanshee's Avatar
yes it sounds like it overheated because they are also air-cooled and when its not moving its not getting any air therefore overheating mine did the same thingduring the winter because all it does is spin. you should get a steel water impeller thats what im doing.
Old Apr 2, 2004 | 06:33 PM
CrAcKhEaD's Avatar
Y steel? doesnt aluminum dissapate heat faster?
Old Apr 2, 2004 | 06:42 PM
yes either will work but you really dont need to dissipate the heat because all it does is pump your anti-freeze into the engine
shimanok2
Jan 29, 2016 07:37 PM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
Elkaholic
Sep 6, 2015 02:44 PM
