How hard is the Blaster powerband
Old Jul 19, 2000 | 12:55 AM
JIGA's Avatar
You can pull great wheelies in 2nd gear and in first. All you have to do is just pop the clutch on 1st gear or just be in second (low reved) and gas it and there ya go ala-wheelie.
Its pretty hard for me to get one in 3rd, but if ya sit on the very back of the seat and gas it in 3rd im sure you can pull one out.
Im 21 5'11" and around 150-160, I have no problems doin wheelies.
Old Jul 19, 2000 | 09:57 AM
99blueblaster's Avatar
There should be no reason for the motor to just blow up if it is taken care of.
-Run good 2 stroke oil in it
-check the plug often so you know how it
is running
-keep the air filter cleaned and oiled(this is
something that is very important in the life
of the motor but most overlooked)
-check compression every couple months or so
My 99 has been riden fairly hard since I bought
it. I keep an eye on the compression and it is still at 127 exactly what it was off the dealer floor.
Trivia time:
If you took a tempature reading on the motor when it was 100 degrees and high humidity and then took one when it was 30 degrees with no humidity which motor would be hotter?
Old Jul 19, 2000 | 07:49 PM
PC_350_Warrior's Avatar
I'm thinkin thats a trick question! I'm going with the 30, no humidity....maybe less moisture to cool it down?? hehe, I dunno about all these guys, my blaster wouldnt pull a wheelie in 2nd....so either they are wrong or I'm wrong....maybe my Blaster had something wrong....
Old Jul 19, 2000 | 08:18 PM
94DGblaster's Avatar
I wish i had your luck, I ran a new uni filter, new reeds, i ran polaris gold 2 stroke oil, and kept an eye on the bottom end oil.
SO i can't say mine was due to my stupidity
Old Jul 19, 2000 | 09:32 PM
  #15
blaster18's Avatar
i can ride wheelies with mine in 1,2,3,4,5,6 but u really cant be like going in 3rd and have it peged and wanting the "powerband to kick in" its not like that at all. its smooth power so if u want to front end up, u got to pull up or slip the clutch.
Old Jul 20, 2000 | 01:55 PM
  #16
BLASTERRYDER's Avatar
my friend can pull a wheelie all the way through his back yard its awsome he is good he just shifts thourgh the gears.when he hits the grab bar he just taps the brakes goes back down its crazy cool he goes prety fast to.
Old Jul 20, 2000 | 06:38 PM
  #17
Duner97's Avatar
When i had my stock Blaster, I could pull wheelies from a dead stop in 1st. If I got going real slow in 2nd, I could pop the clutch, and ride em longer. Or if I took off shifted 1-2- then shifing into 3rd, I could pull the front end up like nothing.
Old Jul 20, 2000 | 06:50 PM
  #18
Y2K300EX's Avatar
My CR80 hit so much harder then a stock blaster. I can hardly feel it on a blaster.
Old Jul 20, 2000 | 07:20 PM
  #19
300expressor's Avatar
do you guys not like, know how to wheelie or something? I mean, come on.. duh.. lean back.. pop the clutch.. give it gas. I have had my banshee for 1 month and I can ride a wheelie in 1,2,3,4. It's simple. You guys should've read dirt wheels "how to ride a wheelie forever" article. Explains it very simple. Forgive me for tickin you off but I mean, come on.. this is simple knowledge.. and my frind, he can ride a wheelie on his 400ex 1,2,3,4,5.. for as long as he's got gas I guess.. seen him out on the lake bed one day, ride a wheelie for at lease 200 yards.. but, that's a 400e 4 stroke. No, a blaster will not pop a wheelie when you hit the power band! Are you talking about taking off in second, or going along in second.. and slowly hit the power band. If so, no. But if you pop the clutch and have it revved.. well, anything will wheelie if you do that! Later,
Old Jul 21, 2000 | 01:31 AM
  #20
Blasters_rule's Avatar
a cheap way to make your blaster have a better powerband is put a k&n filter on there it made a difference in myne
i could hit wheelies through 4th and i run alltracks on myne so dont say that blasters are gutless the reaso0n 80's have better powerband is because all the power from the engine is spinning one skinny wheel instead of two wide ones
