Raptor Question
Old Apr 5, 2004 | 01:56 AM
ChevyBoy's Avatar
Default Raptor Question
Jus bought a new raptor and im about to set it up for aflat track racing...any tips on what to do with it? im thinking of lowering it and putting an Anti-Sway Bar on it..also can you install Anti Sway bars on stock a arms..and im wondering whats the best exhaust for it is...post some links if u can, thanks
Old Apr 5, 2004 | 03:04 AM
Yamaha660R's Avatar
www.cfmracing.com
The easiest way to lower the front of your Raptor. Takes 5 minutes to install or remove, and you can flip the rear linkage to drop the back end.
Old Apr 5, 2004 | 04:00 AM
maddog56's Avatar
Sorry yamaha, cfm wont work here.
An anti sway bar is a must for flattrack. Lower the front either with new shocks or a durablue lowering kit, lower the rear by removing the linkage or a new shock.
You can put the sway bar on stock a arms, but you have to use the stock lower mounting position for it to be effective.
Get some american racer tires, some beadlocks, and a helluva lot more power and you can start racing.
Sparks and CT make the best hp pipes for the raptor. You may want to look into some internals as well.
Firefighter400
Oct 8, 2022 06:38 PM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
