HELP ME!
Old Jul 20, 2000 | 08:57 PM
Blastermon's Avatar
My Blaster sounds like it is still warming up even after it has been running for 10 minutes. I do run pre mix, could the ratio be too rich? I am running a 32:1 ratio.
Old Jul 21, 2000 | 05:04 AM
kidco's Avatar
no i run a 32:1 mix and mine runs fine . when you start your quad do you rev it for at least a minute or two till the white smoke starts to ware off.?
Old Jul 21, 2000 | 09:50 AM
99blueblaster's Avatar
Revving the motor before the piston is at operating temperture is not a good idea.I would not recommend it.
The blaster does seem to take a while to burn the oil left behind in the cylinder from the last ride. The gas evaporates and leaves behind the oil. I always let mine warm up for 2-3 minutes and then take it easy till the throttle response is good. After that hold on. Sounds like what you are experiencing is pretty normal.
