Raptor
Old Apr 14, 2004 | 07:50 AM
YamahaRiderOnly's Avatar
Default Raptor
will a 14 tooth up front put a strain on a Rappy
Old Apr 14, 2004 | 01:08 PM
maddog56's Avatar
Default Raptor
Any sprocket increase puts a strain on the engine, but 14 isnt bad. I never needed a larger front until I had cam, piston, pipe and filter. Even then it was only for a particular flattrack. If you really want to gear up that much (I cant imagine a useful reason why) then you really should reduce the size of the rear sprocket instead. Much less strain on the engine and you are less likely to have to buy a new chain.
Old Apr 14, 2004 | 02:29 PM
xraptor660rRider's Avatar
Default Raptor
If i took the baffle outta the muffler how much faster will it go
Old Apr 14, 2004 | 02:34 PM
TheRaptorMan's Avatar
Default Raptor
I don't know how much faster, but it will be noticable! Pull out the baffle, take the rubber flap off under the tank/ seat, put in K&N and rejet... for about 50$ you will get a significant increase! This is the Easiest and Cheapest mod to make to a stock rappy!
Old Apr 14, 2004 | 03:18 PM
  #15
RaptorOwner's Avatar
Default Raptor
Originally posted by: maddog56
Originally posted by: RoostinRappy
Sprockets are like 15.00 you should get a 15 tooth front sprocket... That is a good way to start and will help out alot!!
What? You should not be running a 15 tooth front on a stock machine. You will lose all kinds of bottom end and it will take you a very long stretch of road to reach top speed. Most stock and piped raptor owners go with a 12 tooth front or equivlent rear sprocket. A sprocket that big on the front puts a serious strain on the engine as well. Its better to change the rear sprocket some as well if not for the entire change.
Yes, go 12 BIG difference over stock. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 14, 2004 | 03:23 PM
  #16
FooBar's Avatar
Default Raptor
first of all, don't be in a hurry. that will co$t you. research your parts carefully. i ended up putting a white bros e-series on, rejetted (gyt-r kit), new filter (gyt-r), removed the air-box lid, and put a 12-tooth front sprocket on. it is a new machine. you won't believe the difference.
Old Apr 14, 2004 | 04:47 PM
  #17
RoostItUp's Avatar
Default Raptor
Ya, I donno where you figured 15 but I'd say go down to 12 and get that acceleration and holeshot. A stock bike WONT be able to pull a 15 tooth countershaft sprocket in higher gears and the lower gears will bog very easily.
Old Apr 14, 2004 | 05:48 PM
  #18
warrior387cc's Avatar
Default Raptor
white bros is the way to go and i'm not just saying that because i have one
my buddy has one on his rappy ,along with a jet kit night and day diffrence
Old Apr 14, 2004 | 10:20 PM
  #19
Default Raptor
If I just pulled out my Baffle on my Stock Raptor would I have to rejet or would it still be a good increase with out rejetting, I also heard it will be way louder, How much louder should it be?
Old Apr 14, 2004 | 11:18 PM
  #20
RedNeckMXRider2's Avatar
Default Raptor
get the yoshimura its got expolsive power gains
