RAPTOR starting problem
Old Apr 14, 2004 | 08:22 PM
BURKEDADDY's Avatar
Default RAPTOR starting problem
hello when i start my raptor in the morning while its cold in gear with the clutch it jumps foward like im not using the clutch but works fine in neutral and when it warms up its fine maybe a hint of the problem but not major like it is when its cold. its also hard to shift out of gear when its cold.i talked to my local dealer when he was doing the brake recall and he adjusted the clutch and he said it was fine that all atvs will do that. is he blowing smoke up my *** is there something wrong?its a raptor 660 2001
thank you for any help you can provide
Old Apr 14, 2004 | 08:29 PM
Rider1169's Avatar
my blaster used to do that until it was warmed up, ur clutch just might be fading a little
Old Apr 14, 2004 | 08:31 PM
caliraptor's Avatar
I think thats normal...once your clutch gets wet and up to temp it wont do that. Mine does the exact same thing.
DTroyer01
Jul 3, 2015 07:34 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
need4aquad
Feb 4, 2001 03:26 AM
RaptorGuy01
Oct 31, 2000 04:23 AM
