help with my banshee
Old Apr 15, 2004 | 03:55 AM
jfoust28's Avatar
Default help with my banshee
I have a 99 banshee with toomey t5 pipes, boysen power reeds, reed spacers,rejetted carbs, and a 4 degree timing key. now my banshee is starting to back fire and spit@sputter from the right cyl. I need some ideas on how to try and fix. I dont whant to take it in to the dealership if i dont have to
Old Apr 15, 2004 | 09:42 AM
sAyIt_fmf's Avatar
It could be a bunch of things...the first thing I would do is a compression test.... That's always where I start..If the pounds are in check...then start looking for air leaks.
-Header tight up against engine
-Carb boot pop free?
-top of the carb is good and tight?
Assuming it was running fine before...no jetting changes.
- is the outside temp drastically different than normal?
- Have you changed fuel or premix?
- are the plugs fresh?
- filter clean?
- Are the carbs in sync?
just some things to think about
Old Apr 18, 2004 | 07:33 PM
lapeerbanshee's Avatar
you probably just need to rejet it because its probably running lean if you havent
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
