eliminating TORS on banshee carbs??
Old Apr 20, 2004 | 07:25 PM
fourjs's Avatar
Default eliminating TORS on banshee carbs??
Just purchased a used 2002 banshee, but after every third ride, the idle goes crazy high, always having to adjust the screws on the tors thing, is there a kit and if so where can i get one, to get rid of the tors and just have a plain looking carb with no high idle problems. hope this makes since, thanks....
2002 banshee
fmf pipes/silencer
reeds/with spacer
rim locks on tires
2 into 1 air filter
Old Apr 20, 2004 | 07:29 PM
FBOMBERS's Avatar
Just about everybody sells them.You'll have to get the tors eliminator kit and an idle kit so you can adjust the idle.It comes with normal throttle caps and everything you need to have normal carbs.Check vitos,they sell em'.
Old Apr 20, 2004 | 08:09 PM
fourjs's Avatar
thanks, i'll check them out, how hard is to install? would basic mechanical skills be enough? and where is Blossom TX??? i live in Kermit, just under the corner of New Mexico/Texas.....
Old Apr 20, 2004 | 10:59 PM
FBOMBERS's Avatar
It's simple,the hardest part is drilling and tapping the idle screw bosses in the carbs and they supply the drill bit and tap.Just make sure you get the slides in sync with each other.
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
