Cannot Get Raptor Sprocket Off!! HELP Fast Plz
Old Apr 22, 2004 | 08:16 PM
KILLERCUDA's Avatar
Default Cannot Get Raptor Sprocket Off!! HELP Fast Plz
I cannot get my raptor sprocket of it is the stock 13 tooth when i try to unbolt it the motor turns over its on there so tight. How the hell do i get this thing off it is a counter clockwise turn correct?
Old Apr 22, 2004 | 08:20 PM
caliraptor's Avatar
make sure its in gear and have someone press on the brake, Im sure your using a breaker bar instead of an impact. If you dont have an impact, go to a tire shop or a truck stop with a tire shop and the guys can take that nut off in a second. I think Yamaha overtorqued them cuz mine was a bi@tch to take off the first time.
edit: and yes, you have to turn it counter clockwise to loosen it up.
Old Apr 22, 2004 | 08:22 PM
Bosch's Avatar
Lots of WD-40
Old Apr 22, 2004 | 09:52 PM
1BADRAPTOR's Avatar
make sure you pull the tabs back, and then get leverage with it, like a big craftsman wrench, i mean like the heavy duty ones, you wont do it with a hand held wrench..
and dont hit it with a impact to put back on cuz you wont be able to tak it off again...my sprocket changes are done in 10 min...alot of practice..
Old Apr 22, 2004 | 10:01 PM
KILLERCUDA's Avatar
Thanks guys I got it off,It was torqued WAY more than 52 ft lbs like my manual said it took a 16" breaker bar and a 12" pipe it was insane. Im no weakling either. A LOT better than stock with that 12 tooth. Thanks again
Old Apr 22, 2004 | 10:14 PM
Bosch's Avatar
What did ya gain with the 12 tooth sprocket,and ,how do ya like the HoleShots,,,,,,,,
Old Apr 22, 2004 | 10:29 PM
KILLERCUDA's Avatar
The 12 Tooth gave me a lot of low-end and a whole lot of quickness. Its like a whole new bike and its stock I like it alot. The Hole Shots are a very good tire provide forward traction and slide when u need them to. A very good tire.....
Old Apr 23, 2004 | 12:05 AM
RaptorOwner's Avatar
I have all ways told people that if you placed a 12 tooth on your stock Raptor that it will fill like you got a new engine. 3rd and 4th gear wheelies are awesome!!![img]i/expressions/face-icon-small-happy.gif[/img]
bmxatv10
Oct 14, 2022 06:23 PM
Hack714
Oct 6, 2015 06:51 AM
Hack714
Sep 26, 2015 08:11 AM
01ssls1
Sep 22, 2015 06:50 AM
Hack714
Sep 20, 2015 05:54 PM
