Where to put resi on raptor????
Old May 3, 2004 | 12:28 AM
DragRaptor727's Avatar
Default Where to put resi on raptor????
where did you guys put the reservoir for aftermarket shocks on your raptor at??? [img]i/expressions/face-icon-small-confused.gif[/img]
Old May 3, 2004 | 12:33 AM
desracers's Avatar
The frame that going down between the oil tank.
That where I put mine of Custom Axis shocks. [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 3, 2004 | 01:31 AM
LOWBOWTIE's Avatar
I put mine on the down tube that the oil tank bolts to.
Old May 3, 2004 | 01:51 AM
sixsixT's Avatar
Me three.
Old May 3, 2004 | 10:39 PM
ok thanks, how about the rear one?
Old May 3, 2004 | 10:56 PM
RaptorOwner's Avatar
I put mine on the front frame bars. The rear one I just cut off...[img]i/expressions/face-icon-small-shocked.gif[/img]
Old May 3, 2004 | 11:22 PM
sixsixT's Avatar
I made a nice bracket for a 01 TCS shock that I had but sold it with the shock.[img]i/expressions/face-icon-small-sad.gif[/img]
Old May 3, 2004 | 11:55 PM
RaptorRacer1's Avatar
If your shock has a short hose about the only place to put it is on the left side lower rail of the subframe. Right about where your leg is. It is a tight fit, but you can make it work.
The best option, if you have a long enought hose (I had to get a longer hose added to my Elka) is to run it up to the front area on the left side by the oil tank. Hope this helps. Good luck.
RR1
Old May 4, 2004 | 01:21 AM
LOWBOWTIE's Avatar
I guess owning a 01 has atleast 1 advantage. A stock place to mount your rear rezzy.[img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
