Polish intake or not?
Old May 6, 2004 | 06:13 PM
caliraptor's Avatar
Default Polish intake or not?
Local speed shop says they can polish my intake/exhaust ports and cumbustion chamber pretty cheap. Most guys get their work done with them around here. Im worried about touching the intake since the roughness helps mix the air/fuel. Should I just polish the exhaust port and the bottom of the head? Im thinking about just getting the exhaust and the bottom of the head done. Any input?
Old May 6, 2004 | 06:36 PM
Ward660R's Avatar
If they said polish the intake and actually mean polish, not port, I don't think I would have them do any of it. Yournot going to gain that much by just having them polish the exhaust, and if your going to enough trouble to pull the head you might as well wait to get it all done.
Old May 6, 2004 | 06:43 PM
wanaply21's Avatar
polishing ur intake will give u a lil bit more top end rev but will loose a lil bottom
Old May 6, 2004 | 06:47 PM
Hozed's Avatar
i agree with ward... you dont polish a intake.
and if your gonna do it... make it worth it.
Old May 6, 2004 | 08:31 PM
roosthrower's Avatar
roflmao. that is definetly going on my list.
Old May 6, 2004 | 09:04 PM
caliraptor's Avatar
Ward-the shop ment just polish, no porting. But they will get rid of some bumps from the casting on both the intake/exhaust. They will just not be polishing the intake. So for around $100 they are gonna get rid of some bumps on the intake and exhaust ports, polish the exhaust and combustion chambers. I think its a pretty good deal.
Old May 6, 2004 | 09:24 PM
you could probably polish the exhaust ports and removing the casting flaws by yourself though. I wouldn't pay $100 for a shop to remove some casting flaws. I would save for a full port job.
Old May 6, 2004 | 10:16 PM
wanaply21's Avatar
i dont get it what was so funny about that? this is what i was told hollywood and i dont think he is wrong unless u can defy someone that been in the motor business for 200 years
Old May 7, 2004 | 01:55 AM
maddog56's Avatar
If you are going to pay them to clean up the castings, then you might as well port it if you want it ported. You dont polish an intake.
Old May 7, 2004 | 02:28 AM
BigBadScrambler's Avatar
They were doing port and polishing in 1804????
