Raptor leaking gas
Old May 9, 2004 | 09:21 PM
RockyLou's Avatar
Default Raptor leaking gas
I noticed a pungent gasoline smell coming from my raptor awhile ago. I looked in the gas tank and noticed that the tank was almost empty. I went to change my oil today and it was almost water. I tried catching the oil and fire and it caught. Somehow gas is leaking into my engine.
If anyone has experienced a problem like this or could help me with this problem I would appreciate it.
Old May 10, 2004 | 04:41 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
sounds like a sticky needle valve or a float that needs adjusting
are your overflow tubes dripping??
Old May 10, 2004 | 11:28 PM
RockyLou's Avatar
My shut off valves don't work for some reason.
Old May 11, 2004 | 01:19 AM
Bing's Avatar
Super Quad Patrol
you must mean the bowl drain screws,,,,,if so,,,,,your needle valves arent seating properly (due to either blockage or floats need adjusting)
common, simple problem
Old May 11, 2004 | 04:22 PM
RockyLou's Avatar
Thanks, I'll check it out.
Old May 11, 2004 | 05:39 PM
Bing's Avatar
Super Quad Patrol
to check them,,,,,get a 1/8 inch (i think) clear tube about 12 " long
connect it to the bottom of the bowl,,,,and loosen the screw about 2 turns so you begin to drain your bowl (be sure fuel is turned on)
your needle valve will open to allow more fuel to come in
hold the clear tube to the side of the carberator vertically pointing up
and see at what level you fuel rises to (in the clear tube)
check each side
let us know how high it goes (in relation to the mating surfaces between the carb and bowl)
bmxatv10
Oct 14, 2022 06:23 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
