New Tie Rods, QUESTION ON INSTALLATION
Old May 10, 2004 | 02:33 AM
Ugintel's Avatar
Default New Tie Rods, QUESTION ON INSTALLATION
i took the old ones off and put a set of new billet aluminum ones on, is there a way to tell if the wheels are straight other then looking?
Old May 10, 2004 | 10:08 AM
artoux's Avatar
Ugintel,
On taking off the old tie rods. I took out the cotter pin and released the nut but the darn tie rod won't come out. What do I do to get it out?
Chuck-Raptorman,
Alba Raptor[img]i/expressions/face-icon-small-sad.gif[/img]
Old May 10, 2004 | 11:02 AM
McFly's Avatar
I use a piece of string tied to 2 poles.....kinda like builders use when laying bricks.
This method is best for camber/caster adjustments
and a tape measure of course.
Old May 10, 2004 | 11:56 AM
Ugintel's Avatar
artoux, you do not have to take those off to install just NEW RODS. leave those nuts on, I just removed the tire to make it more accessable. Turn the handle bars and stick the new rod in, then turn them back and thread bolth ends on at the same time.
Old May 11, 2004 | 12:05 AM
artoux's Avatar
Ugintel and bartlett,
thanks for the tip. My tie rod is aftermarket so it didn't break after all. I just screwed it out.
But the ball joint did on the threaded part. So I have to buy a new ball joint. I left the nut on loosened it up a little and hit it with a hammer not to damage the threads, with a 2x4 also.
Can't get it off maybe I need the ball joint puller you were talking about. where do I get one. I'll call Yamamah tommorrow and see what's up.
Thanks Chuck-Raptorman
Kyle5050
Dec 13, 2019 04:25 AM
MNatv89
Aug 10, 2015 02:20 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Polarisman1123
Aug 3, 2015 02:08 PM
raceware
Jul 30, 2015 06:59 AM
