Raptor tunning question
Old May 10, 2004 | 10:04 AM
Entomber's Avatar
Default Raptor tunning question
I took my Raptor out to PA this weekend and it had a really bad bog down low. I opned up the carbs but I think I turned them out too much. Now it doesn't start. Anyone know what is the proper turning of the air screw and how can I get my arm ripping throttle response back?
Old May 10, 2004 | 10:37 AM
UBETRUN's Avatar
The bog may be your floats, if they flood the idle circuit of the carb it will bog down low. Set your air screws @ 2.5 turns out from all the way in, that should get you started. Once you're sure your floats are good (clear tube method - do a search), you can fine tune the air screws by blipping the throttle and adjusting until the rpms drop right back down to idle. If it takes a second for the rpm to drop, air screws are too lean. If the rpms drop below idle and then to idle, air screws are too rich. Adjust in 1/8 turn increments and your stock head pipe should not glow red.
Firefighter400
Oct 8, 2022 06:38 PM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
