raptor mysteriously bogging
Old May 24, 2004 | 12:20 AM
ripit's Avatar
Default raptor mysteriously bogging
yesterday i replaced stock clucth w/ msr thumb adj. pertch. installed a block off plate for ebrake. removed the two wires that go into the stock pertch and connected them directly. now bike idles beauttifully but when i give it some gas it boggs, when i hit it even more it backfires...what the hell is going on here...got a 6 day trip planned for mem day and now bike doesnt run...any suggestions? thanks
Old May 24, 2004 | 01:42 AM
PabstMan's Avatar
If your talking about the 2 wires coming off the e-brake, DON'T connect them! That's what makes the connection. If you pull the "plug" out of the back of the perch, open the plunger switch (easy), and remove the little brass ring inside, when you put it back together the e-brake retarder won't work. BUT!!!!! be careful, now you don't have a "dummy" way of knowing if your e-brake's on when you give it gas.
Hope that helps![img]i/expressions/face-icon-small-cool.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img]
Old May 24, 2004 | 10:07 AM
ripit's Avatar
when i disconnect the two cables from the perch and then go behind the radiator to disconnect the cables from the harness, i connected them to themselves, completing the circuit. i thought thats what had to be done...
Old May 24, 2004 | 10:19 AM
raptormattman's Avatar
DON"T connect them that is the problem.
Old May 24, 2004 | 10:38 AM
ripit's Avatar
so let me ask you, when i disconnect the two cables from the clutch pertch what do i do with them?
Old May 24, 2004 | 10:41 AM
sixsixT's Avatar
You need to connect the male and female banana plugs together and leave the wires that go to the white connector unplugged.
Old May 24, 2004 | 10:45 AM
pinheadedjoker's Avatar
go to raptortranny.com and look up the raptor reverse limiter thats the porblem i had and took me 5 min to fix it and havnet had a problem sense here is the direct link it helped me im sure it will help you rev limiter
Old May 24, 2004 | 10:57 AM
ripit's Avatar
thanks guys...i will try tonight when i get back to the garage....this day at work cannot go quick enough...i hope its as simple as you guys are making it..ill keep you posted.
bmxatv10
Oct 14, 2022 06:23 PM
Sassinm1
Sep 30, 2015 04:23 AM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
