Banshee foot pegs....
Old May 25, 2004 | 04:36 PM
Warrior01YZ89's Avatar
Default Banshee foot pegs....
the right foot peg on my banshee, the rear bolt keeps falling out. does anyone else have a problem with keeping this bolt in? the threads are stripped inside the hole and i don't know why. i never overtightened the bolt. one day i noticed it was gone and now a bolt won't stay in the hole. any solutions? i thought of a heli coil but are they very trustworthy? does anyone think i could drill through the frame, get a longer bolt, and put a nut on the other side? any suggestions would be very helpful.
thanks
Old May 25, 2004 | 04:40 PM
pinheadedjoker's Avatar
I have a bolt threader and if u cant get your hands on one of those to make it bigger and use a bigger bold i would drill through the frame then put a longer bolt through then used lock tight and a lock washer and make sure its on there good use washers on both sides of the frame that gets rid of virbrations and backing out the bolt
Old May 31, 2004 | 07:42 PM
Jacobs350's Avatar
i would just put some lock-tight on it from the hardware store. if you use a bigger bolt you will not be able to use the pro-peg nerf adapters if you wanted too. i just think drilling the frame is a bad idea, besides the other guy has a raptor.........ewwww
kampswas
Sep 23, 2015 05:05 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
Jul 7, 2015 11:00 PM
