??? RAPTOR cam top tourque specs ???
Old Jun 9, 2004 | 05:11 PM
400exKiller990's Avatar
Default ??? RAPTOR cam top tourque specs ???
Just purchached a new HotCam for my Raptor and need to know the cam top tourque specs if anyone knows. Thanks
Old Jun 9, 2004 | 05:37 PM
caliraptor's Avatar
Dou you mean the gear that goes on the cam(I think 10lbs)? or the entire valve cover(7.2lbs)?
Old Jun 9, 2004 | 05:40 PM
yea, i guess it wouldnt be the cam top ,thats the whole cover. whats the peice called that is (10lbs.)?
Old Jun 9, 2004 | 05:43 PM
UBETRUN's Avatar
The cam gear is 14 ft lbs, use RED loctite and make sure you get the decompression mechanism together properly. The cover bolts are 7 ft lbs and use a criss-cross pattern to tighten them.
Old Jun 9, 2004 | 05:49 PM
sixsixT's Avatar
Aren't the cam gear bolts less torque like 9 ft.lbs. for the hotcams? It gives it to you in the instructions.
Old Jun 9, 2004 | 05:55 PM
UBETRUN's Avatar
Maybe they are? I used the factory specs on the Stage 2 in my 686 and Craycraft's new cam in my 730, it didn't seem to hurt either one.
Old Jun 9, 2004 | 05:57 PM
ill look at the instructions and see but thanks!
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
