??? RAPTOR cam top tourque specs ???
Old Jun 12, 2004 | 01:38 AM
400exKiller990's Avatar
Default ??? RAPTOR cam top tourque specs ???
does anyone know the torque specs for the cam cover in inch lbs.???????
Old Jun 12, 2004 | 04:33 AM
sparkskiller's Avatar
86.4 " lbs
cam cover oil bolt is 168"lbs
Old Jun 12, 2004 | 04:45 AM
yfzblaster1's Avatar
thanks were did you get your info...??
Old Jun 12, 2004 | 04:43 PM
where did you get your info ?
Old Jun 12, 2004 | 04:47 PM
from the yamaha raptor manual
Old Jun 12, 2004 | 04:53 PM
the exhaust tappet covers are 104.4 inch lbs
upper engine mount bolt is 29ft lbs on the nut side 1 each bolt
upper engine mount bolts to the frame are 24 ft. lbs
one thing on this upper mount is to install all bolts loose firt then torque to specs.
to convert from ft. lbs to " lbs just muliply by 12
Old Jun 12, 2004 | 07:23 PM
where did u get that manual is it a cd?
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
