Curious
Old Jun 17, 2004 | 11:37 AM
pinheadedjoker's Avatar
Default Curious
boing
Old Jun 17, 2004 | 02:26 PM
1LeSSRaptor's Avatar
Default Curious
The dynojets move up in increments of 2's. Also, the 466/148 setup that sixsixt told you is the recommended start by Dynojet for your setup. You will never have to go down in jets from the recommendation, usually go up if anything. Put the 146/148 in. It's only one step up from where you are now, but better not ride too much until you get it right, or you'll be paying a couple grand to get it fixed again.
Old Jun 18, 2004 | 08:19 AM
bLuRRRR27's Avatar
Default Curious
heh yah, wouldnt wanna happen to be too lean now...[img]i/expressions/face-icon-small-smile.gif[/img]
-bLuRRRR27-
Old Jun 18, 2004 | 09:34 AM
Freez's Avatar
Default Curious
Dynojets run in 2's up to 150, and then they go up in increments of 5 at a time. You cannot get a 152 for example. Only 150 then 155 and so on.
I am running dynojets 165 and 170 in a stock motor raptor. My mods are in my signature. If you running smaller jets than that on a built motor, you will be way lean. I am at 5000 ft and the bike was jetted on a dyno.
Old Jun 18, 2004 | 10:21 AM
  #15
sixsixT's Avatar
Default Curious
Originally posted by: pinheadedjoker
I gotta figure this out
i STILL think im running way to lean but sixsixt claims i should be running a 144 146 and im at a 142 144..i dont know.. i need to find a damn honest mechanic to do some work i swear the dip that did mine fu_ked me over.
That wasn't me, here's what I posted. I would take Wshrdskin advise he has about the same set up with a DJ kit.
Quote
Originally posted by: RaptorOwner
with your setup I would be running a 146 148 mains and 27.5 pilot. Thats what I was using on my stock carb setup on my 690. Airbox lid off as well.
I would try at least that size jets or 150/155 and 25 pilots even at 4000'. Raptors seem to make better power a little rich rather then a little lean and it's better for your engine.
Old Jun 18, 2004 | 11:07 AM
  #16
Default Curious
I got a 148 and 150 main now and a 25 pilot seems to be running better also i dropped a tooth on the front sproket.. and needle postion is on 4th clip plug was a little past white with teh 144 146 so i jumped it up and i think its good now..
Old Jun 18, 2004 | 11:38 AM
  #17
matykrak's Avatar
Default Curious
Is therte a jetting tutorial somewhere onthe net for people like me who need to understand it better? Like what it all means and how to do it? I dont mean to sound lame But seeing all these numbers confuses the hell out of me. And I hear alot about having piston damage, powerloss etc. by running the wrong sizes. Do I change them EVERY time I do a mod? I guess the only way to do it right is By keep changing them till it all comes together. But I dont even know what signs to look for. Bad Plugs, Backfiring, Popping.. All greek to me.. who can help?
Old Jun 18, 2004 | 04:06 PM
  #18
bLuRRRR27's Avatar
Default Curious
[img]i/expressions/face-icon-small-smile.gif[/img] heh...go by the spark plug color...usually a good tan color, and you should be just about spot on.
But i myself would like to find a good page that explains jetting....as i am jetting out my z400...raptor seemed to be no prob...but this is.
-bLuRRRR27-
flyin-lowe
Dec 1, 2017 03:18 AM
bigred20653
Oct 2, 2015 10:05 AM
cboler9
Sep 24, 2015 08:35 PM
Albertaboyy
Sep 9, 2015 09:51 AM
polarisrider1203
Aug 29, 2015 07:52 PM
