broken degree key? help!!!
Old Jun 19, 2004 | 11:06 PM
soon2bBlaster's Avatar
Default broken degree key?
Today i was riding and i went to shift from first to second but hit neutral. i have the degree key and i think it broke because when i hit neutral it put the extra stress on it. when i took off the cover the flywheel nut was at the end of the threads i cant take off the flywheel until tomorrow because my freind has a flywheel puller and i dont. i tightened up the nut and kicked it and it almost started but it backfired and the second time it almost had an idol but it sounded like gears grinding then stalled. Trenga told me that the degree keys break alot but i dont believe a word from him. i need help as soon as possible
Old Jun 20, 2004 | 12:52 AM
Voodoothenoob's Avatar
Default broken degree key? help!!!
i dont even know what a degree key is...lol
what does it do and where does it go?
Old Jun 20, 2004 | 12:56 AM
its in the crankshaft. it spins the flywheel. the stock name is the woodrov key but the one i have that vitos makes is offset 4 degrees so give the ignition better timing which results in more power
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Sep 2, 2015 11:15 PM
