Changine Raptor Exhaust w/o jetting.?!?
Old Jun 22, 2004 | 11:52 AM
SEMO's Avatar
Default Changine Raptor Exhaust w/o jetting.?!?
Would there be any issues/problems with changing from stock exhaust to aftermarket w/o changing the jets? Taking out of consideration MAX HP etc? Don't really care about getting the max. Would it do any kind of damage to the bike if a person were to switch exhaust w/o rejetting?
thanks
Old Jun 22, 2004 | 01:36 PM
Prophecy's Avatar
You will lose some back pressure lowering your bottom end power by upgrading to bigger pipe. It will be worth your while to jet at the same time and ditch your airbox lid and go with a k&n or comparable air induction system. As far as damage goes I dont think it will hurt anything but you'll lose some of that classic rappy bottom end.
jb
Old Jun 22, 2004 | 01:59 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
may as well do it right
intake/jetting/exhaust
waste of money to just buy an exhaust sytem
Old Jun 22, 2004 | 02:14 PM
Starky's Avatar
You can get away with just going with an after market slip on, but you won't get the full benifit as if you were to replace the air filter and open up the air box and rejet. With just the slip on, you will feel a little more response though.
Old Jun 22, 2004 | 02:45 PM
raptorchick's Avatar
If you don't rejet, and are running lean, you could fry your engine.
Old Jun 22, 2004 | 03:06 PM
Just4Kicks's Avatar
I'm also thinking you might risk running a little on the lean side. I'm no pro mechanic though.
Old Jun 22, 2004 | 03:32 PM
SEMO's Avatar
wouldnt i be able to just adjust my carb settings to prevent it from running lean/frying engine?
Old Jun 22, 2004 | 04:05 PM
Honestly, I can't tell you if adjusting the air mixture screws would be all you need to do. The right carb settings/jetting depends on lots of different things, like your elevation, if you have the air box lid off, if you are using aftermarket air filter.....etc.
Edit: You may want to do a search on this forum for info on raptor jetting. There's a lot of topics on it and lots of useful info.
Old Jun 22, 2004 | 04:16 PM
Bing's Avatar
Super Quad Patrol
the adjustment you talk about is for the idle position only (changing the main jet is the only way to add more fuel at wide open throttle)
you aught to just get a filter and jet kit when you do your exhaust
Old Jun 22, 2004 | 04:26 PM
BALDMIKE's Avatar
Ya I just added a WhiteBro's slip on on my sled and I did notice a difference
without jetting and air lid, but just a little bottom gain.
I am going to get a new full Sparks pipe and then I will jet and do the airbox
Anyone want to buy my WB slip on it's in my pictures....
