carb jetting???
Old Jun 30, 2004 | 12:28 AM
duke9074's Avatar
Default carb jetting???
In order to adjust your main jets 3/4 to rfull throttle you need to rejet right? and for the pilot you can use air fuel for minor and rejet for the major changes? is this correct or could some one explain how this all works?
Old Jun 30, 2004 | 12:10 PM
pinheadedjoker's Avatar
i belive thats the way it works [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 30, 2004 | 12:13 PM
2004LEBANSHEE's Avatar
yup, main jet must be changed to adjust full throttle, and air screws do a fine adjustment to 0- to about 1/4 throttle. Needle is middle
Old Jun 30, 2004 | 02:33 PM
hondabuster's Avatar
Yes, basicly you're right.
There is also a midrange circuit which can be adjusted. The clip position on the needle, can be moved to raise or lower the needle in the needle jet. This will effect the 1/4 to 3/4 throttle.
Heres a good article on jetting.
jetting
Cole Hadden
Jun 15, 2025 09:05 AM
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Jul 29, 2015 09:41 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
