Raptor Carb help
Old Jul 2, 2004 | 07:30 PM
JPBabyRange47's Avatar
Default Raptor Carb help
I just put on a Yoshi slip on, Pro K&N and rejetted with 146/148, 3rd clip on needles and 3 turns out on the mixture screws. My Raptor runs good but I feel like it has lost some top end. I didnt mod my airbox at all except for the baffles. Is this a jetting problem or should I just mod my airbox?
Old Jul 2, 2004 | 07:33 PM
RaptorOwner's Avatar
Well you can be close, anytime you open up the fuel you have to compensate for the air as well. I would try running it without the lid and see how it runs unless your lid holds your airfilter in then I dont know.
Old Jul 2, 2004 | 07:41 PM
I tried running it without the lid and didnt seem much better. I need to keep my lid on because I do ride thru water sometimes. I would rather just cut some holes in it if I have to. In general, if the quad is losing top end what is the problem?
Old Jul 2, 2004 | 08:21 PM
sixsixT's Avatar
Top end would be mains but you should be good up to 2000' or so with those mains. If it's hot humid and your at a higher elevation you might want to try the next size down.
Old Jul 2, 2004 | 09:10 PM
My elevation is a couple hundred feet (100-200) over 2000 ft. Should I change out the mains? If so, which would ou recommend?
Old Jul 2, 2004 | 09:20 PM
sixsixT's Avatar
I would jet it for where you ride the most and just leave it.
Old Jul 2, 2004 | 09:53 PM
Basically, if I am only losing top end, it would be that the jets are to big=rich, so if I do cut some holes in my airbox, then more air should lean it out some??
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
