686 big bore kit?
Old Jul 6, 2004 | 05:33 PM
kawasaki88man's Avatar
Default 686 big bore kit?
I was wondering how much it would cost me to bore my raptor out to a 686?
Old Jul 6, 2004 | 05:39 PM
Yamaha660R's Avatar
A local shop could probaly put a piston and cam in it for pretty cheap.
Craycraft has a awesome 686 kit for $1600. Includes port work and everything. www.14mins.com
You might want to give Bob and call and see about getting your stock carb's mod'd for the 686, and maybe getting a heavy duty connecting rod.
Old Jul 6, 2004 | 06:14 PM
no i ment like how much is it to bore it like the machineing
Old Jul 6, 2004 | 06:20 PM
pinheadedjoker's Avatar
under 100 bucks
Old Jul 6, 2004 | 06:21 PM
warwgn's Avatar
should only be around 40 or 50 bucks, but depends on labor rate in your aera
Old Jul 6, 2004 | 09:26 PM
oo wow i though it would be more i can get a wiseco 686 big bore kit online for i think 150
now would i have to replace my rod and everything?
Old Jul 6, 2004 | 10:06 PM
Yamaha660R's Avatar
Some people change the rod and have the crank balenced, and some don't. I wanted the assurance of no major problem's, and had my rod replaced and crank balenced.
Old Jul 6, 2004 | 10:49 PM
wshrdskin's Avatar
imo, you don't need the 102mm (686) bore to make your quad faster. Buy the stock 100mm piston with compression of your choice and a decent cam to go with it and that new found power is plenty for most trail riders. The extra 26cc won't be very noticable imo.
Old Jul 9, 2004 | 07:29 PM
Voodoothenoob's Avatar
compression of choice....could you give me a couple examples and what they accomplish?
Old Jul 9, 2004 | 09:02 PM
wshrdskin's Avatar
Stock compression. 9:2:1 10:75:1 (11:1) or the 12:1 compression piston can all be had in the stock bore size 100mm. Each one gives you a little more power over the other.
