??? RAPTOR timing ???
Old Jul 13, 2004 | 04:32 PM
400exKiller990's Avatar
Default ??? RAPTOR timing ???
ok i just recently snapped a cam chain, got it repared, timing marks are right one.
took it out for the test run today and it didnt seem to have the torque it did i miean it real close too but...
its also 110 degrees and real humid too tho, i think that might be it
i was wondewring if it was one tooth advanded or retarded what would it do ? would it run? would it start hard?
because now (i think i might have starter probs) its like the starter dont have enough juice to turn the motor over.
thanks.
Old Jul 13, 2004 | 04:45 PM
warwgn's Avatar
if you are one tooth retarted it will act just like you are describing, if it was a tooth advanced it would run better but might not start very well. one tooth is quite alot. I would re check all the timing again, stick a pipe cleaner down the sparkplug hole to make sure the piston is at excatly top dead center, you can watch the pipe cleaner move up and down with the piston. just be very careful you dont turn the engine far enough to let it fall inside the combustion chamber or you get to check the timing the long way!!
Old Jul 13, 2004 | 05:03 PM
if it was one tooth retarded would that put strain on the starter? it acts like it dont have enuff juice to turn the motor but that might just be the starter
Old Jul 13, 2004 | 07:35 PM
pinheadedjoker's Avatar
Hook a battery charger to the battery and then try to crank it.. see if it behaves the same..
Old Jul 14, 2004 | 04:51 PM
yup the same
the battery has 13 volts it got better when i charged it. it starts up now just struggles.
it has to be in the starter i think when the cam chain broke sumthin musta happend when the motor came to rest but i dont know someone said it could be the clutch in the starter but i dunno what ya think?
Old Jul 14, 2004 | 05:47 PM
warwgn's Avatar
take out the spark plug and see if the starter will spin it easy
Old Jul 15, 2004 | 01:41 AM
it does but the starter still sounds funny has a whine to it
Old Jul 15, 2004 | 12:17 PM
warwgn's Avatar
might be a combo of both timing and starter or one way bearing. this may sound stupid but did you adjust you cam chain tensioner after you did everything?
Old Jul 15, 2004 | 03:10 PM
the timing im pretty sure is right on. the oneway looked perfect. and you better belive i adjusted the tensioner this time thats y i snapped the cam chain first when i put the cam in. i belive it just starter problems. we'll see how long it holds up
Old Jul 15, 2004 | 04:37 PM
warwgn's Avatar
last try would be to take the starter apart and clean the brushes and armatures real good with B-12 chemtool, then clean out the housing as well. might make it alittle better. good luck and keep us posted
