Banshee problem PLEASE HELP............
Old Jul 19, 2004 | 10:28 PM
Banshee2001BW's Avatar
Default Banshee problem PLEASE HELP............
My banshee has started acting up. I start it and it idles fine, but when I ride it and gives it alot of gas it acts like it was running out of gas (but the tank is full), then if i give it some choke its OK for 30 feet then it does it again. If I drive it on idle it's fine. I cleaned the carbs like 20 times, I adjusted the floats to specs.I can not figure out what caused this to hapened. Any input would be greatly appreciated.
Old Jul 19, 2004 | 10:31 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
PARKING BRAKE!! that dreaded P.O.S.!! chec kit [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 19, 2004 | 10:39 PM
2004LEBANSHEE's Avatar
yup, TORS at it again.
Old Jul 19, 2004 | 10:42 PM
Speedy2222's Avatar
i hate yamaha's P brake
Old Jul 19, 2004 | 10:57 PM
I checked it it's not the parking brake. I can make it rev for about 30 seconds and the motor screams then it stats acting up. Thanks for trying.
Old Jul 19, 2004 | 11:00 PM
TheBansheeMan86's Avatar
sounds like someone's vent on their gas cap is kinked/clogged. check your vent hose i'll almost guarantee that it is kinked or clogged. it would cause a vaccuum in your full tank, especially when its full [of gas]. it'll run at idle or with choke because it doesnt require that much gas. as soon as you start crackin on the throttle, it demands too much gas.
Old Jul 19, 2004 | 11:15 PM
lapeerbanshee's Avatar
how old is your banshee??
Old Jul 19, 2004 | 11:35 PM
Brap's Avatar
I would say that one of your slides is sticking, but you said you cleaned your carbs, so maybe do a compression check and take it from there.
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
