Banshee Shocks on a Raptor?
Old Aug 3, 2004 | 03:08 AM
6spdta's Avatar
Default Banshee Shocks on a Raptor?
I found a set of Works shocks off a Banshee cheap and am wondering how they would work on my raptor. They are 1 in shorter than the Raptor shocks and I am looking into a lowering kit.
Has anyone tried this?
Old Aug 3, 2004 | 01:51 PM
garyc660R's Avatar
Banshee shocks are horrible. The only way I would use a Banshee shock is aftermarket.
Gary
Old Aug 3, 2004 | 02:37 PM
maddog56's Avatar
Well they are works... better than stock but not a huge leap.
What kind of shocks? Triple rate, dual rate, w/ or w/o res, at steelers or pro?
Old Aug 3, 2004 | 04:13 PM
DieScarred's Avatar
I say save yourself the hassle for the minimal improvement.
Old Aug 3, 2004 | 05:11 PM
maddog56's Avatar
If they are a nice set in good shape by works standards they should be a worthwhile improvement. The valving and spring setup is important though. You would probably need a set of shee shocks set higher than you would your raptor shocks. For instance, if you weigh 175 pounds, then you will need a shock valved and sprung for a heavier rider and/or extended a arms because it is valved according to banshee specs, not raptor.
If its a really good deal, I think its a good move. If you think you can get the money together for a nicer set, then wait and save up.
Old Aug 3, 2004 | 08:39 PM
BURKEDADDY's Avatar
so the banshee shocks front and back will just bolt right up to the raptor with no modifactions?
Old Aug 4, 2004 | 02:13 AM
6spdta's Avatar
They have 3 springs and remote reservoirs. The mounts are a bit smaller but can be fixed with spacing. I was kind of wondering how differnt the spring rates would be.
bmxatv10
Oct 14, 2022 06:23 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 12, 2015 09:39 AM
