Iam an Idiot...
I bought a Speed Beather Valve for my back brake Master cilander and i was puting it on and screw ing it in and then i was going to beath my back bracks so i went to loosen it a little bit and the top snaped off and now i have have a breather in my master cilander any ideas for easy removel any ideas are appriated thanks , Adam
Yea sears has em. they are in the drill bit section and they cost around $12 for a set. you will have to drill into it with a drill bit the use the easy out to pull it out. they also have these new things called bolt out's. its the same concept but their alot more expesive, they run about $40.
