Raptor engine dragging/vibration
Old Aug 16, 2004 | 01:06 PM
blueblood's Avatar
Default Raptor engine dragging/vibration
I went riding yesterday and felt a sporadic vibration that acted like an engine brake. It would start to occur and stay there for a minute or so and then go away. RPM's, throttle position, engine load, etc didn't seem to affect it. I have had the quad a couple of years and not experienced anything like it. I am concerned that it is the transmission going out or another large mechanical failure. Has anybody experienced a drag on the engine similar to this? It is an 01 Raptor with the original transmission and all other original internal parts.
Old Aug 16, 2004 | 01:08 PM
pinheadedjoker's Avatar
Does it seem like a limiter kicks in?
Old Aug 16, 2004 | 01:10 PM
zow's Avatar
zow
what year rappy is it
Old Aug 16, 2004 | 01:12 PM
his is a 01 from his sig.. wasnt it only the 02 and up that had rev limiter probs?
Old Aug 16, 2004 | 01:16 PM
blueblood's Avatar
It is an 01, it almost felt like the chain was being held up by something. It seemed to do it worse when I got in off camber positions or when turning. The engine would still rev fine, it just wouldn't go like it usually does. The loss in power seemed to be between the engine and the rear wheels. Can a stretched chain cause this affect? I currently have the chain adjustment all the way out and it is just barely still within spec.
Old Aug 16, 2004 | 01:24 PM
zow's Avatar
zow
could it possabley be the tranny
Old Aug 16, 2004 | 01:55 PM
blueblood's Avatar
I was wondering if anybody who has an 01 Raptor with a failed transmission (it seems like many do) experienced the same symptoms before it went out. And what does a failing one way bearing feel like?
Old Aug 16, 2004 | 02:32 PM
my failing one way didnt give me any signs it just went along withthe cam chain and flywheel and valves and rocker arms [img]i/expressions/face-icon-small-sad.gif[/img]
Old Aug 16, 2004 | 02:37 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Sometimes you can get some chain slap on the swingarm skidplate that can mimic what you describe.
Take a look at your chain/skidplate (the ones that have the teflon chainguide attached can make an odd noise/clunking)
Old Aug 16, 2004 | 03:29 PM
blueblood's Avatar
Dang pinhead, how much did that set you back? And how much to be proactive and do it before extensive damage occurs?
