Wolverine Question????
Old Aug 16, 2004 | 08:20 PM
hondaguy1's Avatar
Default Wolverine Question????
I have a 1996 yamaha wolverine and when i let it come to a idle and punch it it dies. If i let it reach about 1/4 throttle and then punch it it wont do it. What could be wrong.
Old Aug 16, 2004 | 08:51 PM
HughJazz's Avatar
Checked your air filter. One my wolverine if you hit a puddle fast all the water splashes up under the tank and fills the air box up.
Old Aug 16, 2004 | 09:08 PM
hondaguy1's Avatar
brand new air filter. It is a uni. i dont know if that needs rejetting or not
Old Aug 16, 2004 | 11:29 PM
hondaguy1's Avatar
will a warrior carb fit on a wolverine without any rejetting. I just bought a 1998 warrior carb for it. I think they are the same thing. THANKS
Old Aug 17, 2004 | 02:34 AM
Rock777's Avatar
I'm not sure if it will fit or not, but I am pretty sure they are different sizes. I believe the warrior carb is a 36mm while the wolverine is 34mm. I wouldn't think putting in just a uni filter would cause you to have to rejet, but I guess it is possible. Did you try driving with the choke on to make it run a little richer? If it doesn't die, then it probably does need to be rejetted. What kind of filter did you have on before the uni? The reason I ask is because if for some odd reason you are getting less air flow now, the carb might be bogging and dying from being too rich and getting too much gas. You could see if it does it with your old filter again and go from there.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
