Banshee problem?
Old Aug 24, 2004 | 09:08 PM
GottaGoRealFast's Avatar
Default Banshee problem?
Yesterday i went outside an i was gonna clean it . My banshee isnt in a heated garage or anyhting just under a roof . So i go outside put the key in give 3 pumps on the gas and pull the choke give a good kick nothing , give another nothing , an so on and on . Some of my buds stopped by today an there like how is the shee i was like well it wouldnt start the other say so i gotta go get plugs an stuff for it , an there like lets fix it so i got the key never pulled choke or nothing an held the gas a qauter of the way b/c i dont know how to idle it higher , when it rolled got messed up . well the shee started rite up the first kick todayy so what could this problem be?
Old Aug 24, 2004 | 09:54 PM
enFORCER's Avatar
Hmmmmmm, from what I can gather there, sounds like you might have flooded it the first time..
Old Aug 24, 2004 | 10:03 PM
I kicked it enough times where it shoulda un flooded
Old Aug 24, 2004 | 10:07 PM
ElectricShift's Avatar
Engine dont un-flood from kciking it over...
Old Aug 24, 2004 | 10:26 PM
Sandfox24's Avatar
Try the throttle wide open while kicking when you flood it.
Old Aug 24, 2004 | 11:12 PM
2004LEBANSHEE's Avatar
Do it this way. turn gas off after last ride. Then when you wanna ride it again shake it for a min. then turn gas on, pull choke all the way out, and kick without hitting the throttle. If jetted right you should never hit the throttle when starting it or when letting it warm up. It should do it on its own.
Old Aug 24, 2004 | 11:25 PM
thats a good idea
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
