Dyna FS for a raptor
Old Aug 31, 2004 | 10:36 AM
  #21
Dfitz's Avatar
Default Dyna FS for a raptor
Stock cdi works. I have had my reverse light taken out. I put it back in and is always on now. I took it out because the other after market cdi would make it blink.
Old Aug 31, 2004 | 10:46 AM
  #22
RaptorOwner's Avatar
If you put it all back to stock, it should work correctly. place your reverse limiter back on.
Old Aug 31, 2004 | 10:53 AM
  #23
Dfitz's Avatar
That is my next goal to make sure it is all back to stock.
Old Sep 1, 2004 | 01:05 AM
  #24
Dfitz's Avatar
Okay, It's working fine now. It was the reverse limiter wire. It was cut where the ripper rev limter box went. So I don't know why the stock worked and seemed to rev fine. I can feel a little difference in the curves. Can't wait to try it out on some longer runs. Also have my tach and shift light working. I have to work on a mounting bracket. Thanks for the help.
Old Sep 1, 2004 | 01:38 PM
  #25
cool, Dynatech told me I couldnt use that reverse rev limiter on it unless I hooked up a different way which I havent looked into that either.... What tach did you use?
Old Sep 1, 2004 | 01:52 PM
  #26
Dfitz's Avatar
Stewart Warner Ultra Shift Light. Blue led Nice looking unit just have to find a good way to mount it that will look good. http://www.sw-performance.com/Prods/14-UltrShfts.html Do you have the info you could pm me on how to set up RL box?
Old Sep 1, 2004 | 02:17 PM
  #27
Call Dynatech and they will assist you. I spoke to them about it but never wrote down that info. When I get ready I will call them back.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
