raptor axle nut came off today
hello agian everybody i am in need of help once again anywho i took my 2001 yamaha raptor 660 in to have the chain cut adjusted and clutch lever installed and for an overall inspection they tightend my axle nut because they were loose, first ride out i heard a noise a clatink sorry the best way i can describe it but i got back and the outside axle nut was complety off the threads and the chain adjusters were loose like they havent been tightend. the axle nut will not go back on im hoping it striped the nut and not the axle,is this something that just happens?did the dealership screw me?where can i find some new axle nuts cheap i looked on rocky mountain and the only ones they have are the lsr for over a hundred dollars i found this one on ebay axle nut anyone have any comments on this axle nut on ebay does this replace both nut or do i have to buy 2 of them?
thank you for any help or advise you can give me.
Originally posted by: caliraptor
Just put some loktite on them and tighten them up.
is it cool to ride the quad with only one of the nuts on it?
Originally posted by: elraptor02
the dealership! blame them!
Originally posted by: RaptorOwner
Yes, if you just got the bike back from them yes I would take it back and have them replace your axle too!!![img]i/expressions/face-icon-small-wink.gif[/img]
thank you
The same thing happened on my dirt bike 2 days ago. Im not sure about your raptor but my bike has a cotter pin hole through the axel that your supposed to put the pin through and forgot to do that[img]i/expressions/face-icon-small-shocked.gif[/img] But any ways a regular nut of the same size will do(any hardware store should stock the same size nuts and that will do fine) and if that wont go on you need to take your axel off and throughly inspect the threads. (it should be obvious from up close whether the nut cross threaded, the axel threads did, or the nut just vibrated loose. good luck!
