comp help
Old Aug 30, 2004 | 07:07 PM
pinheadedjoker's Avatar
Default comp help
Originally posted by: yamrpt660r
are they all updated w/ latest definitions?
btw what in the happend to your valves, ect?
me????
Old Aug 30, 2004 | 07:10 PM
yamrpt660r's Avatar
Default comp help
me????
yup looks bad
Old Aug 30, 2004 | 07:17 PM
Default comp help
welll.. the bolts backed out of the flywheel and hte oneway gear stripped them off.. once that happend the flywheel slid out a litlte bit which strtched the cam chain. which broke hte cam chain which hit the valves and borke them. and broke the cam chain guides in the crankcase.. teh reason the valves are white is becuase i was running a tit lean lol i was at a 142/144 now i am up to a 185/190 dj.. so yeah shes good now [img]i/expressions/face-icon-small-smile.gif[/img]
RaptorOwner's Avatar
Default comp help
Originally posted by: duke9074
i got somwe thing called sysfader when eve ri go to use a windows open like pc doctor or norton or system restore or and tihng thats original liek that it wont let it open help me plz norotn does not find the virus and adaware does not ither.
go to start, then run and type msconfig and press ok. Go to the farthest tab to the right called startup. Turn everything off except anything that is running in the symantec folder then close it and reboot. Then run ad-ware at www.lavasoft.nu and then run it. Delete anything and everything it finds and reboot again and if its still there, your going to have to FORMAT your hard drive cuz you must have a new nasty browser hijacker installed.
Old Aug 30, 2004 | 08:58 PM
  #15
yamrpt660r's Avatar
Default comp help
i think you mean the magneto, that happend to me except the exploding of the ENtire valve train
i forgot to clean the oil out with brake cleaner but it just sheared them off
your lucky the cam chain dident CRACK the head $500..
uh i wouldent format.. since thats not too serious eventually if it is spyware adaware or someting will put it in their updates why not just use a new browser thats better? say firefox? www.mozilla.org
jrooker6
Jun 17, 2015 12:28 PM
Joey9
Aug 21, 2001 05:59 PM
ERICsRAPTOR
Mar 10, 2001 02:38 PM
Mike Frey
Apr 19, 2000 09:20 AM
gollem
Where to Ride
10
Feb 27, 2000 06:12 PM
