raptor leaking oil from head??
Old Sep 12, 2004 | 08:06 PM
Rider1169's Avatar
Default raptor leaking oil from head??
i am so angry. riding today and noticed oil leaking slowly from the right side of the head. its a slow leak, but its leaking. has this ever happened to anyone else?
Old Sep 12, 2004 | 08:14 PM
caliraptor's Avatar
Is it coming from a hard line? or from between the head and cylinder?
Old Sep 12, 2004 | 08:22 PM
Rider1169's Avatar
its like the gaskets went bad, its leaking from the head and the cylindar. i never opended the engine yet, so i dont understand why it would be the gaskets, its only a few months old
Old Sep 12, 2004 | 09:08 PM
caliraptor's Avatar
I had a cluth cover gasket go bad all of a sudden too...I think this would be a good time to put in a bigger piston and maybe port it out...you would be looking at $600 with cometic gaskets, porting and a new piston if you did the work yourself
Old Sep 12, 2004 | 09:18 PM
warwgn's Avatar
better pull the vave cover and check there first, if you over heated the cam it can cause a leak, usually only if you have run it low on oil or some trash clogged a oil passage.
Old Sep 12, 2004 | 11:41 PM
Rider1169's Avatar
well, this doesnt sound like a serious problem right, its def loosing oil tho. slowly. i can pin poin the leak, but it appears to be coming out of a crack where the head and cylindar meet. it still runs totally fine.
Old Sep 13, 2004 | 05:47 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
My new one is leakin right there and its gettin fixed right now under warranty. It happens.
Old Sep 13, 2004 | 06:28 PM
Rider1169's Avatar
you found it was just the gaskits?? or was it something serious
Old Sep 13, 2004 | 06:33 PM
pinheadedjoker's Avatar
sounds like a new gasket will do ya better.. i mean its worth a try.
Old Sep 13, 2004 | 06:35 PM
Monkey Rider
Afro-Engineer
Mine looks like it is either leaking outta the top port for that external oil line or out of the cover bolts. or outts the cam cover gasket. when i switched to silkolene atv oil it is a lil thinner than yamalube so it was leakin more. always sompin. [img]i/expressions/face-icon-small-mad.gif[/img]
