370 Banshee
Old Sep 27, 2004 | 12:43 AM
FMF's Avatar
FMF
Default 370 Banshee
Ok I want to have my Banshee Bored out to a 370 and I dont know who to send it to? And it is ported with race logic sport port should I have it reported?
Old Sep 27, 2004 | 01:09 AM
JakalWarrior's Avatar
Default 370 Banshee
Its not a good idea at all. Next time you have to rebuild your top end youll have to get a new sleeve and get it re ported. Not to mention you wont gain enough to notice, you could take a **** before a race and gain more advantage. The reason people have 370s is because that used to be the only way to use a long rod (had to use blaster pistons, and thats their minium size).
Old Sep 27, 2004 | 01:12 AM
FMF's Avatar
FMF
Default 370 Banshee
I was also thinking about haveing it bored 40 over? Right now it will run 300ft in High 4s to low 5s.
Old Sep 27, 2004 | 01:32 AM
sredish's Avatar
Default 370 Banshee
Boring it .040 over will do nothing for your performance, seriously. If you want a true 370 setup. Get a pair of +5mm rods, and some Wiseco 795 pistons. Those pistons are the same as the stockers except the rod attaches higher up in the piston so no borework, headwork or spacing is required. You'll have to have your crank rebuilt with the rods, but it's cheaper than buying a long rod crank, and you'll have to have some port work done as well, but it'll be worth it.
Either do that, or buy Vitos 404 kit and have it installed, you'll still have to have some portwork done to flow properly, but there's no "free" horsepower gains out there.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
