Best mod for low end power
Old Oct 3, 2004 | 10:48 PM
kawasaskirules's Avatar
Default Best mod for low end power
i have a 04 400 kodiak and would like to know whats the best mod for the most gain in low end power?
Old Oct 4, 2004 | 12:41 AM
MNWolverine01's Avatar
I actually have the same question for a 2001 wolverine.
Ryan
Old Oct 4, 2004 | 12:42 AM
nosliw's Avatar
hmf [img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 4, 2004 | 01:25 AM
JakalWarrior's Avatar
Best ways to get more low end power.... more compression, or more CCs, or both. A high compression piston and bore/hone cost the same as or less than most exhaust systems but their a bit harder to install. Go to high and youll be running race gas. Big bore kits are sometimes are easy, sometimes not.. Same goes for their price. Depends on the motor.
Old Oct 4, 2004 | 11:33 AM
HoundDog06's Avatar
Well said Jackal. I would say, start with a pipe. If that's not enough, increase your compression. Then try an aftermarket cam and port/polish job. How mean can you afford to be? [img]i/expressions/face-icon-small-wink.gif[/img]
~HoundDog
Old Oct 4, 2004 | 02:56 PM
hondabuster's Avatar
Smaller dia. tires will increase the power on the low end. A smaller diameter carb, will increase the velocity of the mixture and will improve the low end. A cam change to one with the properties you want, and a bump in compression. All these are tradeoffs, what you gain down low , youll lose on the high end.
Most pipe and jetting changes improve the midrange and high end.
Too bad you didnt get the 450 kodiak, it has a low range, which really improves the low end torque, getting to the tires.
Old Oct 4, 2004 | 03:48 PM
big bore and compression wont hurt their top end though since those motors dont rev high enough to notice the extra piston weight or increased pumping losses.
Old Oct 4, 2004 | 04:22 PM
Boxhead's Avatar
I would strongly agree with everyone else. Speaking about carbs the edelbrock gave me a nice punch in the lows and mids, and a tuneable accelerator pump will give you an awesome response if you don't already have one. One of those torque stuffers are a really cheap way to add a little punch in the low end also.
Old Oct 4, 2004 | 04:42 PM
alright thanks guys i have never seen a pipe for a 04 400 kodiak
keep them coming though
Old Oct 5, 2004 | 12:43 PM
HoundDog06's Avatar
Here is an HMF Engineering pipe for the kodiak.
~HoundDog
