steering stem?
Even if the steering stem is bent a little, you may be able to get the handle bars pointing straight by adjusting tie rods. I did this on my Banshee and worked fine until I bent it again really bad and then I went ahead and replaced steering stem.
I had this same thing happen to me. Low speed collision and the bars were crooked. The steering stem was straight, but the bar clamp that is machine pressed on to the steering stem twisted on the steering stem. I tried everything to twist it back to no avail. I gave up and just adjusted the tie rods. I could turn too good to the left, but the right turns were a bit more interesting. I have since wiped out the tie rods and broke down and bought a new stock stem. Which will probably twist again, but I can't justify a $300 steering stem to the wife. Just my 2 cents.
My friend thought he bent his stem, but it turned out the ball joints on the tie rods got punched in and stripped the threads a bit. That is definately a possibility. Funny part is he bent the stem later on a stump, and fixed it accidently by hitting a stump on the opposite side. I wouldn't recommend doing that though! lol
Sep 30, 2015 01:37 AM
Logan Collins
Sep 5, 2015 08:03 PM
