Cheapest mod. for speed...
Old Oct 11, 2004 | 05:33 PM
JTY2K's Avatar
Default Cheapest mod. for speed...
I noticed that when I went from 4.5psi to 6psi I gained about 3mph on topend on my 01 Raptor with stock tires. Anyone else found similiar results? Can't prove it, but seems like to bike pulled faster.....[img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 11, 2004 | 06:01 PM
maddog56's Avatar
Yes, higher tire pressure increases the tire's diameter and therefore changes the final drive ratio resulting in higher top speed.
Old Oct 11, 2004 | 09:16 PM
ZimRaptor's Avatar
turbo
Old Oct 11, 2004 | 11:23 PM
maddog56's Avatar
Originally posted by: ZimRaptor
turbo
3500 bucks for the basic kit plus install and all the extras is very obviously not the cheapest modification for speed.
Try to bring something constructive to the conversation.
If you get a smaller rear sprocket or larger front sprocket you can increase speed as well. But if you get a larger rear or a smaller front you can increase your accelleration. So unless you ride at over 70mph all of the time and need more speed, then I suggest the latter.
Old Oct 11, 2004 | 11:36 PM
adambomb04's Avatar
stage 1 or stage 2 hotcam improves in the top end, had mine done and there was a big difference, make sure you have after market filter and jetted and pipe....
Old Oct 12, 2004 | 01:05 AM
Raptorboy4life's Avatar
would you just put a cam with a piped raptor? or should you put a higher comp piston in it too?
Old Oct 12, 2004 | 01:11 AM
maggiesboy's Avatar
"One Wheel Short"
It costs nothing to uncork the exhaust and remove the airbox lid. aka hillbilly speed!
Old Oct 12, 2004 | 07:50 AM
ZimRaptor's Avatar
turbo
or you could go to a junk yard and take one out of a van...smart@$$
Old Oct 12, 2004 | 02:14 PM
delow350's Avatar
or a leave blower...
Old Oct 12, 2004 | 11:16 PM
Jibrille's Avatar
I was going to say larger front or smaller rear sprocket, but maddog beat me to it.
