banshee jetting HELP ME!
Old Oct 12, 2004 | 02:36 AM
superevil's Avatar
Default banshee jetting HELP ME!
OK,i was running K and N filters on my 91 banshee,with no air box,i also run an old DG (i think) 2 into 1 exhaust,so it comes out the back as a single exhaust.I wanted to switch back to a regular stock airbox,because i ride in a lot of mud and water.So i put on my new banshee stock airbox and filter,and now the banshee wont rev out.If i take the lid off of the air filter box,it runs fine.I messed with the air screws a bit(that didnt help)---So with the airbox lid on im not geting anough air. Right now im running a 25 pilot,and a 290 main jet. What should i change jetting wise to correct this problem. maybe a smaller main? like a 260?
Old Oct 12, 2004 | 05:21 AM
2fun's Avatar
You are starving the motor for oxygen, so you will need to go down on the main jet by at least 2 jet sizes (would be my guess). move the needle clip UP one notch, and you may or may not also have to go down a size on the pilot jet.
Be sure to do a plug check with a fresh white plug after doing these jetting changes.
I would start out there and see how that affects it.
Old Oct 12, 2004 | 07:06 AM
superevil's Avatar
Thanks,i ride a lt250 myself.My girlfriend rides the shee,it ran really nice with the k and n's on it,but i couldnt get her to stay out of the water or mud,and i dont want to be rebuilding it.It ran great without that lid on.Ill try that advice today
Old Oct 12, 2004 | 12:30 PM
quadracer18's Avatar
Ya, your defenetly to high on the main jet. your pilot should be fine. If you never changed your needle position then I would leave it alone unless your jetting/air mixture is a hair off after rejetting down.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
